29% off Nissan Skyline GTST R33 Coilover
Postby Karylisa » Fri Sep 29, 2017 2:05 am
Fitment:
For Nissan Skyline GTST R33
Features
* Adjustable pre-load spring tension
* 24 levels of adjustable damper -- This allows you the ability to perfectly dial in your coilovers system. For a nice comfortable driving, set damping to full soft. For more spirited driving, set it to 16 clicks. For occasional track days, set it to full stiff.
* Pillow ball top mount -- this design helps combat noise while tuning. It also improves the steering feel and response
* Most components are made from 6063 aluminum with T6 for increased hardness -- the advantages include excellent strength, and aluminum helps keep the weight down.
* Hi Tensile performance spring - Under 600,000 times continuously test, the spring distortion is less than 0.04%. Plus, the special surface treatment is to improve the durability and performance.
* All inserts come with fitted rubber boots to protect the damper and keep clean.
* Improve your handling performance without sacrifice comfortable ride.
* A fast and affordable way to easily upgrade your car's appearance.
* Easy installation with right tools.
* Ideal for any track, drift and fast road and can also be used for daily driving.
Get:http://www.maxspeedingrods.co.uk/high-performance-nissan-skyline-gtst-r33-24-ways-adjustable-coilover-suspension-kit-x4pcs.html
Karylisa
Return to General Discussion
Users browsing this forum: No registered users and 23 guests
