Neutral position faulty switch?
Postby Wr1darcy » Mon Apr 27, 2015 4:46 pm
After being on the rolling road, was told the neutral switch was faulty,
Has any one else had this problem ? And where is it located ? Any advice would be marvellous
Wr1darcy
Re: Neutral position faulty switch?
Postby Gee Wr1 » Sat May 02, 2015 12:02 pm
It's quite a common thing to wear out. I've not had to do mine but what i gather from reading about folk needing to replace it is that its a plastic piece (thats why it wears out) situated on the top of the gearbox, it has to be replaced from under the car and can be akward to reach. The likes of Alyn (ASP) has the knowledge and will be able to give you the full answer and how to replace it.
Postby W1 KRB » Sat May 02, 2015 3:49 pm
Yep mines been done
W1 KRB
Postby john » Sat May 02, 2015 4:49 pm
So what are the symptoms of a faulty NPS?.
john
Postby W1 KRB » Sat May 02, 2015 4:50 pm
Unfortunately I couldn't tell you because it was done a few weeks before I brought my car! Have receipt from Autotecnica that it was done
W1 KRB
Postby Wr1darcy » Sat May 02, 2015 6:28 pm
To be honest I wouldn't have known it was at fault, I've read it can effect performance, boost problems etc.
But advised it needs replacing. So will do for peace of mind
Cheers guys.
Wr1darcy
Postby W1 KRB » Sat May 02, 2015 6:40 pm
Not an expensive job
W1 KRB
Postby silver-sonic » Sun May 03, 2015 6:56 am
apparently restricts boost as it thinks car is in neutral.
most people dont know its doing it till getting map done from what i heard.
silver-sonic
Return to General Discussion
