Help & Advice ( Malfunction indicator lamp)
Postby SUBDJ » Sun Apr 17, 2011 4:09 pm
Hi there some advice needed please :( ,I took the 1 out for a spin last night took her up to 8 k in fifth and i think she hit the limiter there was a loss in power then has you change into sixth off to go again with no problems at all pulled back up the rev range.On returning i notice the Malfunction indicator lamp was on permanently (OBD SYSTEM).The Owners book says to take it to dealers to sort.Also check this morinng light still on.
The owner book reads
If light comes on steadly while driving or does not go out after the engine starts an emission control system malfuntion has been detected.
Subdj
SUBDJ
Postby WR 1mposter » Sun Apr 17, 2011 5:22 pm
Try turning ignition on/off 3 times ! I
It has been known to clear malfunction warning. !
Spot on(turn on off three times)
Postby SUBDJ » Sun Apr 17, 2011 6:01 pm
Your the man WR1 IMPOSTER spot on just tried it light gone out.
Many thanks WR1 IMPOSTER for taking the time to reply.
:D Subdj
SUBDJ
Postby CAVEMAN » Mon Apr 18, 2011 6:56 am
make sure you are running 99 V Power only dude..
the light can come on due to knock (pre-detenation) will crappy fuel and give you this warning.
have to be prepared to change gear BEFORE you put your foot down...those revs get eaten up rather quickly!
Postby SUBDJ » Mon Apr 18, 2011 10:04 am
Thanks cavman i am runninig 99v.possible i took her up to high??
SUBDJ
Postby Crockel » Mon Apr 18, 2011 5:14 pm
The ECU records these faults so the next time you are near your friendly mechanic pop in and ask him to check- 2 minute job.
If it comes on again make sure you drive it off boost.
L
Crockel
Return to General Discussion
