different turbo's
PostPosted: Mon Sep 07, 2009 7:29 pm
by jimmy
whats the difference with all the turbo's?
tdo5/6,vf35?
what's the difference between ihi vf and td0?
the td turbo is easy to get,tdo4 is small and td08 is huge,but what with the rest?
i dont even know what kind of turbo my car has,i know it aint the same as the wr1 turbo,the wr1 has like a metal cover,mines is just a turbo with a red pipe comming out of it?
it aint important but would like to know
cheers :lol: :D 8)
PostPosted: Mon Sep 07, 2009 11:01 pm
by WUZ
TD series of turbo were made by Mitsubishi (evo TD turbos rotate the opposite way to Subaru TD turbos).
TD series are THRUST BEARING turbo's, the TD ** indicates Exhaust housing size.......
TD04 - WRX, UK Turbo (96-)
TD05 - WRX UK Turbo pre-96)
TDO6 - bigger housing that
eNOTE: TD04 is actually a TD04-13G
TD05 is actually a TD05-16G
aftermarket turbos can be made to have have bigger Compressor wheels and housings eg TD05-18G, TD05-20G
IHI are made by IHI and are ROLLER BEARING TURBOs for the most part...............
See below :D
VF22
This turbo has the highest output potential of all of the IHI VF series turbos and is the best choice for those who are looking for loads of top end power. The top end power however, does not come without a cost. The VF22 spools significantly slower than the rest of the IHI models due to the larger P20 exhaust housing and is much less suited for daily driving than some of the other models.
VF23
This turbo is considered a great all-around turbo. Like the VF22 it utilizes the largest P20 exhaust housing. This housing is mated with a smaller compressor housing of the of the VF24. This turbo is considered optimal in applications with range from mild to slightly wild. It does not have the same top end power of the VF22, but spools up significantly quicker.
VF24
This turbo shares its compressor housing with the VF23 however, this housing is mated with a smaller (P18) exhaust side. The smaller characteristics of this turbo allow it to provide ample bottom end power and quick spool.
VF28
This turbo came standard on the STi Version 5. In terms of overall size, it is smaller than the VF22, VF30 and VF34, and about same size as the VF23.
VF29
This Turbo is nearly identical to the VF24, with the same compressor and exhaust housings. However the compressor wheel in the VF29 is has been changed slightly. The changes made to the compressor wheel in this model are generally viewed as improvements, and as such this unit is typically chosen over the VF24.
VF30
The VF30 is commonly considered the best bang for the buck turbo in the IHI VF series line. A relatively new model the VF30 features the same exhaust housing as the VF24 but a larger compressor side similar to the VF22. The combination of these two parts results in increased output potential without the lag associated with the VF22. Although it doesn't offer the top end supremacy of the VF22, the VF30 is a great compromise between these unit and the quicker spooling models.
VF34
The VF34 is nearly identical to the VF30, with the same exhaust housing and compressor. However the VF34 goes back to the ball bearing design, and in doing so achieves full boost approximately 500RPM sooner than the comparable VF30. The VF34 is the most recent IHI design and as such costs slightly more than its counterpart. Top end performance and maximum output are identical to the 30.
VF35 (WR1 TURBO)
VF35 The VF35 has identical internals as the VF30 and it uses divided thrust bearings. However, the exhaust housing is a P15 which means this turbo will have fantastic spool characteristics. This turbo is standard on the new WRX Type RA. LIMITED SUPPLY.
VF36
Roller bearing version of the twin scroll VF37, also has a titanium turbine and shaft for even quicker spool. Same compressor housing as VF30/34, however twin scroll P25 exhaust housing provides slightly better top end output due to reduced exhaust pulse interference. This turbo is good for 400HP and used on JDM STI Spec C from 2003 onwards.
VF37 (thrust bearing)
Enter the age of twin scroll IHI turbos. Same compressor housing as VF30/34, however has a new twin scroll P25 exhaust housing that provides slightly better top end output due to reduced exhaust pulse interference. Twin scroll also provides better spool up for improved low down response over the VF30/34. This turbo is good for 400HP and used on JDM STI from 2003 onwards.
VF38
Twin scroll turbo with titanium turbine and shaft. Smaller compressor housing than VF36/VF37 provides tremendous spool up capabilities but less top end than VF36/37. The spool capabilities of this turbo are demonstrated on the JDM Legacy GT, which reaches peak torque at 2400RPM.
VF39
Single scroll turbo used on USDM STI and latest 2.5L STIs released internationally. Smaller than VF30/VF34.
VF42
Exclusive turbo to the S203/S204 models, this features a twin scroll design with a slightly larger compressor than the VF36/37 turbos and different turbine design (more blades). The VF42 is a roller-bearing turbo and is likely of similar size to the VF22 turbo, but with twin scroll exhaust housing for faster spool and superior top end performance due to reduced exhaust pulse interference.
PostPosted: Tue Sep 08, 2009 12:03 pm
by Megaman
Wow now that is a comprehensive list.
I suppose for none techys the turbo manufacturers should produce power curves of each turbo so you can see graphically and easily where the power comes in, how much you can get out of it with regards to torque/bhp.
I find turbos that spool up mid range best personally. The ST for example had a low spooling turbo which would give full whack at 1500rpm. Results in loss of traction low down and you dont need to rev it as much. The modified scoobs ive been in with higher rpm spooling turbos tend to be very laggy and then give you shed loads of power once in the power band.
When driving on country roads mid range feels to best for me but obviously in a drag race or straight line motoring you would want the most power which would be the laggy but mega powerful turbos...
PostPosted: Tue Sep 08, 2009 2:09 pm
by 500tie
So whats best then a td type turbo or an IHI??
PostPosted: Wed Sep 09, 2009 11:54 am
by John Mc
I've had most of thoses turbo's on my WR1 (without realising)... :lol:
